Geosystem/Analytica
http://geosystema.net/eforum/
How to use an Immersion compatible mouse
http://geosystema.net/eforum/viewtopic.php?f=1&t=20
Page 1 of 1
Author:  Sergey Oleynik [ 29 Aug 2006, 13:04 ]
Post subject:  How to use an Immersion compatible mouse
How to use an Immersion compatible mouse and customize its buttons?
To use the 3D-mouse with Delta software you have to connect it physically to a com-port of your PC and copy IBOX32.DLL file from Immersion setup CD to your \Delta folder. Then run Ged.exe and set Immersion compatible mouse in Tools|Options|Harware|Human interface device.
To assign your favorite commands to different mouse buttons (up to 16 buttons) you can edit IBOX32.INI file. Line started with # at the beginning of this file are comments and then you will see button assignment, that look like Button1=Number_Of_Command. Change command numbers for appropriate buttons to desired ones and then restart Ged.exe program.
To download Ibox32.dll/Ibox32.ini files, follow the link http://www.vingeo.com/update/Ibox32.zip
Page 1 of 1 All times are UTC
