Geosystem
Instruments and software for digital photogrammetry
It is currently 26 Apr 2024, 01:01
Post new topic Reply to topic  [ 1 post ]
Author Message
 Post subject: How to use an Immersion compatible mouse
PostPosted: 29 Aug 2006, 13:04
Administrator
Administrator
User avatar
10 May 2005, 14:01
How to use an Immersion compatible mouse and customize its buttons?
To use the 3D-mouse with Delta software you have to connect it physically to a com-port of your PC and copy IBOX32.DLL file from Immersion setup CD to your \Delta folder. Then run Ged.exe and set Immersion compatible mouse in Tools|Options|Harware|Human interface device.
To assign your favorite commands to different mouse buttons (up to 16 buttons) you can edit IBOX32.INI file. Line started with # at the beginning of this file are comments and then you will see button assignment, that look like Button1=Number_Of_Command. Change command numbers for appropriate buttons to desired ones and then restart Ged.exe program.
To download Ibox32.dll/Ibox32.ini files, follow the link http://www.vingeo.com/update/Ibox32.zip
Delta/Digitals developers team
Top
 Profile E-mail
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 15 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
